Water remainsBosch
Alexei
 Water remains
Post by Alexei »
Good evening!
I have a Bosch SRV55T03 dishwasher, it’s about 13 years old. Today a peculiarity was discovered: the machine washes normally, but after the end of the program there remains water inside, about 0.5 cm, which was not there before. If you turn on any program for a short time, the first thing that happens is that the water is immediately pumped out by the pump and the washing begins (the pump works normally), but at the end there is still water left. Please give me some advice, what could all this be?
  • Foam remains after washing
    by belmari_66 » » in AEG
    Last post by Splinter
    by Olga Olga » » in Indesit
    Last post by Olga Olga
  • Overflows water. Leaking from water hardness regulator
    by Artem » » in Electrolux
  • Water does not flow into the dishwasher. No water. Reasons for the error.
