Error E4 and no water supply ⇐ Chrono
Автор темыDmitry79
- Новичок
- My dishwasher: Krona BDE 4507 EU
Good day ! We have crown 4507. The device is 7 years old. I got it after buying an apartment. such a problem. It turned out when removing it to inspect why the water was poured out - the water supply hose to the tank on the right was torn from the fitting. The E4 error has disappeared. turned on. The water was pumped out, and then the fence began, but the connection began to siphon and eventually broke. the water just came out under pressure. I turned it off, removed 2 water intake hoses on the tank, connected the water supply hose, the water went from where the water intake is put on. I guess the conclusion is that the drainage system and where the water circulates is clogged or what kind of valve? Everything inside the filter is washed. and extracted. The question is how to bleed the system, where to find the blockage. After all, the water supply is ongoing and the pumping is working. The plug prevents water from collecting and further flowing through the drainage. Help with advice on where to make out what to look for yourself. call a technician just call 500, diagnostics will reveal the cause 700. and then in the end, maybe I can do everything myself and they’ll take it from above. Or they’ll add a reason for which they’ll rip you off. Maybe there’s business here for 5 seconds. I wish I knew where to pick. It is logical to assume that you need to remove the pan and look at the filters there. but, blowing it out or whatever, I need advice. Cleaning and blowing like that, their price tag is also 1,500 rubles. It will be funny when they do the actions in front of me in 5 seconds and everything works when I could do it myself.
- Участник
Re: Error E4 and no water supply
Try this method viewtopic.php?f =21&t=172
and check float in the pan
Автор темыDmitry79
- Новичок
no float. maybe somewhere in the pan. In general, I called the master. and the law of meanness. he put on a hose that flew off the water supply. secured it with a clamp. Then I just loaded the baskets and said turn them on. As a result, the fence started working. Everything was fine. I gave money 800 rubles for the clamp. I found the problem myself.
- 13005 Views
Last post by nickolai.cotov
