water in the panAEG
Nick
 water in the pan
Post by Nick »
Good afternoon, dear forum users.
AEG dishwasher Error 30 is constantly triggered. I removed the side cover, turned on the machine for 30 minutes and noticed that water was emerging from two overflow hoses from the dishwashing chamber. Moreover, the water does not drain constantly, but only when there are 13 minutes left on the display until the end of the wash. I looked at the filters - they were clean. The openings in the dishwashing chamber are located under the door and they are located quite high. 150-200 g of water drains during the entire washing process. Tell. Please. what could be the problem?
    by Olga Olga » » in Indesit
    Last post by Olga Olga
  • Overflows water. Leaking from water hardness regulator
    by Artem » » in Electrolux
  • Water does not flow into the dishwasher. No water. Reasons for the error.
  • Hard water
    by Retire » » in General questions about dishwashers
    Last post by when
