Leaking SPV69T00Bosch
Apc
 Leaking SPV69T00
Post by Apc »
Built-in dishwasher (5 years). Previously, the aqua-stop worked once every couple of months, but after drying it worked normally again. The aqua-stop hasn’t worked for half a year, but the dishwasher has started leaking. I can’t figure out why, every 3-5 washes a puddle appears to the left of the car, soapy, dirty, not very salty (no more than a glass). The puddle appears quickly, i.e. not in drops, but all at once. Tell me what’s wrong with her. The door seals are good, everything under the door is dry, the drain hose is intact.
 Re: SPV69T00 leaking
Maybe due to dirty filters or the drain, try cleaning it according to these instructions viewtopic.php?f=21&t=172
Yuri
Интересующийся
Интересующийся
Post by Yuri »
If you spent the winter with water, look for a crack in the salt tank; If you spilled salt and did not turn on the rinse according to the instructions, then the salt could gnaw a hole in the washing chamber. Does the leakage sensor work? Check the bottom of the door seal for deformation.
  • The dishwasher is leaking! Help!
    by URKINS » » in Indesit
  • The dishwasher is leaking, can anyone tell me?
    by Lyokha » » in Bosch
    Last post by ivan. orlov
  • ESL65070R is leaking
    by GuitarFan » » in Electrolux
  • Wellton WDW T5 is leaking
    by not » » in Other manufacturers
    Last post by not
  • Leaking from under the door
    by artem.bardij » » in Electrolux
    Last post by Timer
