The dishwasher is leaking! Help!Indesit
URKINS
Post by URKINS »
The Indesit D61 machine suddenly started overflowing water yesterday. :( :( :(
What could be the problem? Maybe the level sensor is covered? Where is it located? I machine I looked it up, but I can’t find it.
Commands
 Re: Dishwasher leaking! Help!
Post by Commands »
If the car is old, then the hose connecting the tank to the pump may simply crack. Check it out first.
adm2
Администратор
Post by adm2 »
URKINS, first try to understand where the leak is coming from: from below, from the front, or from somewhere on the side? Before starting, remove the side cover. If at the front, check the seals. If on the side, then Comandos wrote to you correctly - look at the hoses, as well as the clamps on the pipes, they sometimes loosen, and sometimes it’s enough to tighten them.
And be careful! Any leak increases the risk of electric shock! Therefore, make sure that the environment is dry while the machine is leaking, and do not allow children near it.
I had one later because a child tore off the rubber gasket from the door. Luckily I didn’t tear it into pieces, so I put it back in and voila. :)
The dishwasher is leaking from the bottom left near the back wall.
  • The dishwasher is leaking, can anyone tell me?
    by Lyokha » » in Bosch
    Last post by ivan. orlov
  • HELP THE PYRAMIDA DISHWASHER IS LEAKING
    by Andrey » » in Other manufacturers
  • Bosch dishwasher Rinse aid dispenser is leaking
    by right1 » » in Bosch
    Last post by right1
  • Leaking SPV69T00
    by Apc » » in Bosch
    Last post by Yuri
  • Wellton WDW T5 is leaking
    by not » » in Other manufacturers
    Last post by not
