ESL65070R is leaking ⇐ Electrolux
Автор темыGuitarFan
- My dishwasher: ESL65070R протекает
Video of the problem:
n
What could it be problem?
Looks like the bottom seal needs replacing?
n
My darling
Re: ESL65070R is leaking
Everything there needs to be disassembled and looked at, maybe a seal, maybe connections of pipes and hoses, maybe the drain hose is damaged, corrosion can happen, a crack in the salt tank, maybe just tighten the clamp somewhere)))
Fork
How to make sure that it is leaking, say, from a seal? In the video, it’s dripping from these two pipes, do they come from under the seal? It seems to point to him...
Retraction
It looks like there is a leak from under the glass of the washing tank, there is a rubber seal there, but this is not certain, I agree with the previous answer that you need to disassemble and look, all the components are connected by pipes and hoses, in general it is good to check the water fill, circulation or drain paths, see clamps, seals, seals, pipes
Fork
The glass of the washing tank is what is located under the lower seal/rubber under the door?Retraction: ↑15 May 2022, 13:26 It looks like there is a leak from under the glass of the washing tank, there is a rubber seal there, but this is not certain, I agree with the previous answer that you need to disassemble and look, all the components are connected by pipes and hoses, in general it is good to check the filling, circulation or draining the water, look at the clamps, seals, seals, pipes
Fork
Another question, is it possible to simply cover the bottom elastic band with silicone to check if it leaks?
Slope
The glass of the washing tank is where the filter is inserted in the washing chamber, you need to look for the reason and not cover it with sealants, in the video it is leaking from two hoses, you can’t just pull them out, coat them with sealant and put them back in, you need to take everything apart and check, I can write you a hundred reasons leaks, this will not change the situation, you need to disassemble and look, maybe it is leaking where there should not be water at all
Nippers
Understood. What kind of hoses are these? Where do they lead? Are they needed to ensure that water flows into the pan in case of a leak?
Slope
There are a lot of videos on YouTube with analysis of Electrolux dishwashers, mostly leaks, it’s better to see them once, there are answers to all your questions about glasses, hoses, trays, silicones and what flows where
Puppeteer
Found the reason:
n
Drips from below under the glass of the washing tank.
Do I understand correctly that it needs to be disassembled and sealed with sealant?
n
Nippers
Is it difficult to apply sealant yourself? I need to unscrew 4 screws and the part at the bottom will come off?
Can someone share a video of how they seal the same area that I need with sealant?
Or is the task not so simple and something can be done do it wrong?
Nippers
Do I need some special sealant, or can I use any? I have intertool universal sealant, will it work?
Nippers
Is it possible to cover it without turning it over and dismantling the entire dishwasher? That is, just unscrew 4 screws, lower the part a little and cover it up?
Автор темыGuitarFan
For a while, sealing it with sealant helped, but recently it started leaking again. I decided to try to cover it up again - it didn’t work at all. I waited more than 24 hours and turned it on - it immediately started leaking. What could be the problem? Why doesn’t it even stick to silicone anymore?
Victor
It is necessary to replace the O-ring with a new original one and seal it not with silicone, but with polyurethane sealant for gluing auto glass. The initial cause of the leak is the incorrect and unequally spaced arrangement of the mounting points for the pallet; the gasket is not evenly pressed against the body; this is not a modification of this model.
- Участник
- My dishwasher: Ariston LSV46ABK , Ariston LSV68DUO IX
The best solution is to find a similar one seal from Ariston (namely Ariston, not Hotpoint) you can safely buy a used one, install it and forget it .... In Electrolux, rubber bands dry out and leak over time, hoses are the same in Ariston, they are eternal!GuitarFan: ↑13 Mar 2023, 18:39 Sealing it with sealant helped for a while, but recently it started leaking again. I decided to try to cover it up again - it didn’t work at all. I waited more than 24 hours and turned it on - it immediately started leaking. What could be the problem? Why doesn’t it even stick to silicone anymore?
- 3180 Views
Last post by GuitarFan
- 2 Replies
- 1537 Views
Last post by ivan. orlov
- 33742 Views
Last post by not
- 2 Replies
- 16944 Views
Last post by Yuri
