Hansa ZWM 627IH does not heat waterHansa
kstvmx
My dishwasher: Hansa ZWM 627IH
Post by kstvmx »
Hello everyone.
The Hansa ZWM 627IH dishwasher does not heat the water.
I did:
I checked the heating element with a resistance tester - ok.
I connected the pressure switch, which is near the heating element, to it tester and blew into it - ok.
The second pressure switch, which is screwed to the side wall below, blew into it with the tester - ok.
Now the interesting thing:
A sensor is installed on the salt container . Does anyone know what kind of sensor this is? If this is a temperature sensor, then when heated, the resistance increases and does not decrease, as it should be in a sensor of this kind, as far as I know, therefore it is faulty.
If this is not a temperature sensor, then where in a car of this model can I find this one? sensor?
In general, I will listen with interest to everyone who has shaken up their PMM, and especially if you have a Hansa ZWM 627IH.
Another question: pressure should be built up only in the PMM hydraulic system or in the "dishwashing area" too? How viable is the version about dirty seals that do not fit tightly to the door?
 Re: Hansa ZWM 627IH does not heat water
Look at the reasons listed for poor heating and the solution here, it may help: viewtopic.php?f=21&t=172[/url]
  • PPM Hansa ZIM 206 H does not take up water
    by Maksim » » in Hansa
    Last post by Maksim
  • HANSA ZIM 676H Does not drain water.
    by Robert » » in Hansa
    by Yulia » » in Electrolux
  • doesn't heat water
    by Vitana » » in Siemens
  • HSIE 2B0 does not heat water
    by PotatoMonster » » in Hotpoint-Ariston
    Last post by I kneel down
