PPM Hansa ZIM 206 H does not take up waterHansa
Maksim
Post by Maksim »
Good afternoon!
Hansa PPM, the washing cycle was interrupted by opening the door for 5 hours. After closing the door it did not work (it hummed, but did not draw water). There are no leaks, the pan is dry. Leakage sensor (connected to the foam float) - working. The electronic aquastop broke (checked with a voltmeter), replaced it with a new hose with an aquastop. The first start - I took in water and washed everything perfectly. I turn on the second one for the next wash and the pilot turns it off. I plug it directly into the outlet, it starts working, but after 40 minutes a new aquastop is covered. Do I understand correctly that most likely the problem is in the board? And tell me where it is located on the Hansa ZIM 606H. Is it possible to install a hose without an aquastop? Thanks in advance for your answer.
  • Hansa ZWM 627IH does not heat water
    by kstvmx » » in Hansa
  • HANSA ZIM 676H Does not drain water.
    by Robert » » in Hansa
  • Hansa 416
    by Irina » » in Hansa
    Last post by Irina
  • Hansa ZIM 446 EN
    by Right » » in Hansa
    Last post by Right
  • PMM Hansa
    by HF » » in General questions about dishwashers
    Last post by HF
