Good day everyone!
I have a question: the sink is completely clogged and the dishwasher drain is connected to it. I poured Pink Mole (lye) into the sink, which naturally ended up in the dishwasher, since the sink was full of water and the dishwasher was constantly pumping the water back, which was poured into it from the sink through the drainage system.
After removing the blockage, everything in the dishwasher was covered in foam from the Mole..... I did several rinse cycles, everything went away, I washed everything with a sponge.... but what about the salt container ?
explain by what principle the water comes into contact with the dishwasher chamber, where was the liquid with the mole in the sprinkler? Well, that is, I wonder if a mole got into this container and how to clean it out then? because you don’t want the dishes to come into contact with this chemical
Cleaning after getting Mole (remedy for blockages) ⇐ General questions about dishwashers
Автор темыdfmodsf8sdhfoisdhu
- Участник
- My dishwasher: Ariston LSV46ABK , Ariston LSV68DUO IX
Re: Cleaning after getting Mole (clogging agent)
Hello. The Mole definitely didn’t get into the salt container; water gets there only through the water supply!
Cargo
Please tell me, can I add mole or tiret to the dishwasher?
Peter
Well, for example, if you suspect that the hose has been forgotten and it’s not so easy to bring a specialist because the house is located far from the nearest city and the hose cannot be removed since the dishwasher is built into the furniture
Marusya 1997
Good afternoon!
Share your experience, have you tried adding Mole?
- 4 Replies
- 55837 Views
