The dishwasher stopped cleaning normallyIndesit
Lina
Post by Lina »
Dishwasher Indesit 051 EU. A year of use - excellent. The dishes were shiny. Powder-salt-rinse aid. Sometimes I use tablets. I didn’t change the detergent. No, I did, but everything was fine. And now she’s started to cower. A white coating began to appear on the dishes. It is washed by hand. But who needs such work... There is this coating on glass, on pots everywhere. Even if it’s 70 grams, there’s still this coating. On a glass shelf that hangs in the kitchen for 4 drops of fat were not washed off several times. I cleaned the filters, ran it with vinegar, there is salt, I played with the rinse aid, I set different dosages, but still THIS RAID. I called the water utility, so they say, the water seems to be soft. But I’ll try to call the laboratory assistant only tomorrow to know for sure. What should I do, please tell me??? I don’t want to go to service yet. We live in a small town, it’s a long drive. Maybe I can handle it myself.
Dimitri
Post by Dimitri »
Did you look at the nozzles in the blades that spin and spray water?
The holes there are small, and they often become clogged with all sorts of fish bones and other bio-debris.
Lina
Post by Lina »
I looked. I constantly clean filters and injectors. I remove the leftovers from the plates. So everything is in order there.
 Re: Dishwasher stopped cleaning normally
Have you resolved the issue with the raid?
Look - viewtopic.php?f= 21&t=193, possible causes are listed here, try cleaning dishwasher, as described in the instructions, since not only filters can become clogged. It may also be a matter of the rinse aid and powder itself, i.e. you can try to change them, well, in 4 years the ion exchanger, which is responsible for softening the water, could well have failed, but then it’s a service center.
  • Cleaning after getting Mole (remedy for blockages)
    Last post by Marusya 1997
  • During cleaning, the pump cover (black part) was removed.
    by Natalie » » in Hotpoint-Ariston
    Last post by Natalie
  • Stopped draining and starting
    by Dimon » » in Candy
    Last post by Dimon
  • Indesit stopped washing the dishes.
    by Euphoria » » in Indesit
    Last post by Kreutzkopf
  • The overflow valve is constantly clogged with mucus, cleaning only helps temporarily
    by Sergio » » in General questions about dishwashers
