what about the salt?Beko
tannics
Post by tannics »
Help!!! The salt indicator came on. We fell asleep and turned it on. Salt deposits, you have to rinse 10 times. Over the past 2 weeks, we’ve already fallen asleep 3 times!!!! packs of salt, but the result is the same - after the first wash the indicator lights up again and until the salt is washed out of the machine, a white residue remains. Maybe I shouldn’t bother anymore - wash out all the salt and work on just the tablets? The machine has been in intensive use for 8 years now.
Goodman
 Re: what's wrong with the salt?
Post by Goodman »
I think that the seal of the ion exchanger salt reservoir is broken, and liquids flow freely from compartment to compartment. This means there is no point in adding more salt. Use tablets or powder only.
Thanks, wash tablets or salt tablets? I really don’t know if there are any. The white coating persists when using different types of tablets, I read that this is due to hard water (((
Goodman
Post by Goodman »
Tablets for washing dishes.
Guest: The white coating persists when using different types of tablets
Do you add mouthwash?
tannics
Post by tannics »
Thank you, mouthwash doesn’t help. Yesterday my husband diluted salt in water and added it when washing, it seemed to work. While we’re at it, we’ll call a repairman as soon as possible.
taniki: We will call a technician as soon as possible.
Eight years is a long time for a dishwasher. If the problem is corrosion, then there is hardly any point in repairing it; it’s easier to buy a new one.
Why is there water in the salt compartment? Is this necessary or is there something wrong?
Guest: there is water in the salt compartment
Do you see water when you unscrew the neck cap to add salt? That’s where the water should be, brine to be more precise.
Look at what could be the reasons http://posudomojki.ru/viewtopic .php?f=21&t=193, but your ion exchanger most likely has failed, judging by the age of the dishwasher
    by Sibiryak22 » » in Candy
    Last post by Sibiryak22
  • salt
    by little » » in General questions about dishwashers
  • Salt container
    by Constantine » » in Indesit
    Last post by Constantine
  • Is it possible to use PMM without a salt tank?
    by DoubleFace » » in General questions about dishwashers
