problem with water drainage. error e01 appearsBosch
Dmitry
Post by Dmitry »
Please tell me what could be the reason!?
I turn on the machine, it works. But when it comes to draining, the work stops and error e01 appears. after I reboot the machine. and I press a program, for example rinse, and then I press reset (3 sec), the timer writes the remaining time 0:01, the water is drained and it signals that the work is finished. Naturally, the dishes remained dirty, perhaps even hot, but dirty
It works fully for about 15 minutes, probably depending on the length of the program
PMM bosch SPV58m10
Please help me, what is the reason.??? thanks in advance
after I wrote the post,
I decided to check to see if something had changed
I ended up turning on the power, the machine grunted in the drain area and gave error e01
 Re: problem with water drainage. error e01 appears
"the machine grunted in the drainage area"
Check the drain hose, "grunting" clearly indicates that it is clogged
Dmitry
Post by Dmitry »
What exactly to look for in the hose? And tell me why, at the time of work, the program requires draining, it doesn’t look like it’s stitched together. And when I run the program and manually do reset . Does it look like it merges?
Try cleaning the filters and drain, as written here: http: //posudomojki.ru/viewtopic.php?f=21&t=172
Dmitry
Post by Dmitry »
I tried, the same nonsense
The problem is this. Water does not drain while the machine is running. It gives error e01. If you wait about an hour and turn it on again, run the program and after a couple of seconds press reset. Then the timer says 0:01 remains. I close the lid. The water is drained. And the car honks. How the program ended. Thank you very much
Good evening. Please tell me. The dishwasher is new beko, we have been using it for about 2 months. We got error E 01 in the instructions it says that there is water in the machine and the water is being drained. What to do It drains for a long time, maybe this is a glitch... how to fix it and what to do.
Good evening. After starting the dishwasher, error E01 appears within a minute. How will it be eliminated???
It happened too. It turned out there was a blockage in the drain hose.
burn
Post by burn »
Hello!!! How to prevent error e 01, something can be poured into the drain system? So that the drain hose works? Do salt and washing tablets not help in cleaning the drain hose?
Splinter
Post by Splinter »
Why pour anything, the chemicals for cleaning pipes are very caustic, they are mainly intended to remove blockages in pipes, but the PMM drain hose can be ruined by such cleaning, there have been cases when the product for removing blockages in pipes corroded the rubber gaskets of the siphon, in general the drain hose itself is very rarely gets clogged with anything, mostly there are blockages in the filter of the PMM itself, and mucus appears in the siphon and in the sink drain over time, all this mass accumulates and the drain becomes clogged, it’s a matter of time, for example, once every 6 months I disassemble the siphon and sink drain, that’s all I wash it with regular soda in warm water, 30 minutes and everything shines :-)
  • problem with water drainage
    by He was satisfied » » in Bosch
  • Water appears at the bottom of the back wall and gurgles
    by Constantine » » in The mud
    Last post by Bagerny
  • Solving the problem of error E19 in the Bosch SPS46MI01E PMM
    by Cool » » in Bosch
    Last post by Cool
  • AEG F96542 VIO Got a problem with water heating
    by Alex3012 » » in AEG
    Last post by Alex3012
  • The icon (machine care function indicator) appears
    by Artemy » » in Electrolux
    Last post by Artemy
