Water appears at the bottom of the back wall and gurglesThe mud
Constantine
Post by Constantine »
There is a groove at the bottom of the back wall; when filling and washing, water appears in it and gurgles; sometimes drops fly out of the machine. This is fine? Or did they forget to put a gasket there?
Bruce
 Re: Water appears at the bottom of the back wall and gurgles
Post by Bruce »
Same problem, the machine was touched for the first time. Water also flies out from there. Did you find the answer? Is this ultimately normal or not?
Bagerny
Post by Bagerny »
after starting, after 3 minutes E 1 is displayed
  • problem with water drainage. error e01 appears
    by Dmitry » » in Bosch
    Last post by Splinter
  • Water from the sink drips to the left of the dishwasher wall inside from the vent
    by Guest » » in Bosch
    Last post by Air Shower
  • Muddy water at the bottom of the PMM
    by AndreiZ » » in General questions about dishwashers
    Last post by Support
  • How to put it back?
    by Andrey Izh » » in Bosch
    Last post by Andrey Izh
  • PMM Bosch SMI65M65RU/32 - leak between the wall and the heat exchanger
    by Monty » » in Bosch
    Last post by klexey
