Reasons for the appearance of a white coating on dishes after washingFlavia
If you have a white coating after washing dishes, the reasons may be as follows:
n
The simplest:
1 ) water softening salt has run out (add salt);
You can see more details about why salt is needed in this video:
2) low-quality rinse aid (try changing to a different brand of rinse aid);
3) low-quality dishwasher detergent in the form of 3-in-1 tablets (also try replacing).
Reasons of medium complexity:
1) the dishwasher requires cleaning (run it dry using a special dishwasher cleaner). It is recommended to do such cleaning at least once every six months;
2) filters are clogged (check the filters).
Instructions on how to fix this problem:
Cleaning the dishwasher
Complex reason:
Out The water hardness detection sensor is faulty (here you will need to contact service specialists).
Reasons for the appearance of a white coating on dishes after washing - banner_1000.jpg
  • After washing the dishes have a white coating
    by Dmitry Katanaenkov » » in Bosch
    Last post by Dmitry Katanaenkov
  • The dishes are not always clean, there is a white coating, the powder is not washed out and sometimes gets attached to the dishes.
    by MyDoHoles » » in AEG
    Last post by Arseny
  • PMM Beko DIS 25010 - leaves a white coating, runs out of salt quickly
    by Elena K » » in Beko
    Last post by Cargo
  • Plaque on dishes after washing
    by Stealth » » in Dishwasher chemicals
  • Salty dishes after washing
    by Sergev.an.cap » » in Beko
    Last post by Aggregate
