The dishes are not always clean, there is a white coating, the powder is not washed out and sometimes gets attached to the dishes.AEG
MyDoHoles
My dishwasher: Aeg ProClean
Post by MyDoHoles »
What to do? Can some parts be replaced? Maybe add a conditioner?
 Re: The dishes are not always clean, there is a white coating, the powder is not washed out and sometimes gets attached to the dishes.
Post by Fulcrum »
MoiDoDir: 10 Feb 2023, 10:28 What should I do? Can some parts be replaced? Maybe add rinse aid?
Costs of the "cost-effective" technologies of modern dishwashers... Try changing the detergent, for example to Fairy, changing or adding rinse aid will not do anything ...
Matrix
Post by Matrix »
First, look to see if there are blockages, check the filters, impellers, the water drainage path from the PMM, the water supply pressure in the PMM should be normal, this problem also happens from short washing cycles, an overdose of detergent, an incorrectly selected washing mode, or from poor quality detergents.
  • After washing the dishes have a white coating
    by Dmitry Katanaenkov » » in Bosch
    Last post by Dmitry Katanaenkov
  • Reasons for the appearance of a white coating on dishes after washing
  • Dishes smell like dog after being washed
    by Tatiana » » in Bosch
    Last post by Guest12345
  • Dishes in the upper basket are not washed
    by Basil » » in Bosch
    Last post by Basil
  • PMM Beko DIS 25010 - leaves a white coating, runs out of salt quickly
    by Elena K » » in Beko
    Last post by Cargo
