DIS-4530 does not clean wellBeko
certificates
My dishwasher: веко dis-4530
Post by certificates »
The dishwasher has been in use for just over a year. After the start of operation, the water hardness value was not set - as it was by default - and it worked. The tableted product ALL in 1 Somat was used. The first months of soap were excellent - the dishes and the dishwasher itself were shining.
It should be noted that the water hardness is high. I don’t know exactly how much - but at the maximum values ​​​​that are permissible for the water supply of a residential building.
Then I began to wash it poorly - there were even food residues - everything was not even washed off. I cleaned the filters, although they were not dirty.
I changed the product to a separate one - salt, powder, rinse aid, different tablets all in one.
Sometimes the soap was good, but most often it was bad. As a result, the conclusion was made that the product had nothing to do with it.
I ran several cleaning cycles.
Now the situation is as follows - the all-in-one tablet product is used. There is also salt in the dishwasher.
dishes after washing with a strong white coating. also the case itself has white streaks inside.
I wanted to adjust the water hardness, there is not a word in the instructions on how to do this. Inside the machine itself, on the left side there is something similar to a hardness adjustment knob and it has values ​​from 1 to 5. But it doesn’t turn. or rather, it turns a little - and the wheel itself comes out of the grooves and is removed - behind it is a white plastic piece that looks like a lever - it does not spin.
how to tighten this rigidity?
 Re: DIS-4530 does not clean well.
Look here for possible reasons for the appearance of plaque: http://posudomojki.ru /viewtopic.php?f=21&t=193 And most likely you have the last option. If you have a question about how to tighten the hardness, it is best for you to contact the manufacturer of your dishwasher, maybe they will fix the problem
  • Beko DIN 4530
    by Garik » » in Beko
    Last post by Garik
  • DIS-4530 dry salt tank
    by certificates » » in Beko
    Last post by Yuri
  • Only clean water for washing.
    by woanarges » » in General questions about dishwashers
    Last post by woanarges
  • Bosch SPS40E42 how to clean
    by Silen » » in Bosch
    Last post by Silen
  • The dishwasher doesn't clean
    by Dmitry818 » » in Hotpoint-Ariston
    Last post by Dmitry818
