Beko DIN 4530Beko
Garik
 Beko DIN 4530
Post by Garik »
I ask for help)
I stopped drawing water... You turn it on, drains the water, but there is no flooding, then there is silence.
I decided to check the aquastop. Blocked, applied voltage directly to it, does not open. It turns out that this is the problem?
I also tried to connect the hose directly to the dishwasher, water flows, but the flow does not stop. There seems to be a valve there for the supply, shouldn’t it cut off the supply?
  • DIS-4530 does not clean well
    by certificates » » in Beko
  • DIS-4530 dry salt tank
    Last post by Yuri
  • Beko DIS26012
    by DeN102Russia » » in Beko
  • Leak BEKO
    by Kir_lp » » in Beko
    Last post by Cathead
  • Beko does not drain water
    by Lord Curzon » » in Beko
    Last post by Lord Curzon
