Water leaks from the ventBosch
Alex
My dishwasher: SMS53N78EU/50
Post by Alex »
Water flows into the machine through a ventilation hole (like a lid with a gray grille) inside on the left side.
Water begins to flow when water is poured into the sink.
Dishwasher drain hose raised by a loop above the level of the bottom of the kitchen sink, !!!
Therefore, water when drained into the sewer should not flow into the dishwasher. *x)
The connection point between the drain and the siphon is located below the sewer pipe.
And the dishwasher stinks a lot. All filters are clean. The sewer pipes are clean and water flows easily from the sink into the drain.
What can I check and try? :read:
Most likely this is some kind of malfunction of the dishwasher.
alex
 Re: Water leaking from vent
Post by alex »
I took it apart and looked - the seal between the ventilation casing and the tank was broken. Water penetrates, the tank begins to rust around the edges of the hole. You can’t tighten it too much - without a tool, just use your hand. Tomorrow I’ll buy silicone and try to seal it.
:read:
Air Shower
Post by Air Shower »
The same situation, as they decided???
Water begins to flow when into the sink water pours out.
The dishwasher drain hose is raised by a loop above the level of the bottom of the kitchen sink, !!!
Therefore, when drained into the drain, water should not flow into the dishwasher. *x)
The place where the drain connects to the siphon is located below the sewer pipe.
And the dishwasher stinks very much. All filters are clean. The sewer pipes are clean, water flows easily from the sink into the sewer.
What can you check and try? :read:
© Source: Water leaks from the vent
  • Water from the sink drips to the left of the dishwasher wall inside from the vent
    by Guest » » in Bosch
    Last post by Air Shower
  • Water leaks from valve SMV25AX00E
    by Like Tishka » » in Bosch
    Last post by Alexander SZAO
  • Leaking from hydraulic valve vent.
    by fa11er » » in Beko
    Last post by Reset to zero
  • Leaks through the dispenser seal
    by ahtq » » in Discount
    Last post by ahtq
