Hello. It leaks through the dispenser seal on the PMM KDI 45570 and I can’t figure out how to remove it. Could you explain to me how it is attached and how it is removed. Saipu dispenser number model sp-d02b.
Thank you.
Hello. It leaks through the dispenser seal on the PMM KDI 45570 and I can’t figure out how to remove it. Could you explain to me how it is attached and how it is removed. Saipu dispenser number model sp-d02b. Thank you.
Colleagues. The lock on the AEG is worn out. You need a dispenser cover 4006078028. The thing is not unique, it is also suitable for Electrolux, but you can’t afford to buy it for 2000 rubles. Maybe someone has it lying around? Peter
Hello! Stopped shooting tablet in the process of washing dishes. I took the door apart. I examined the contents. I rang the coil - 1333 Ohms. Everything is bad? The wires suitable for this coil go somewhere under the bottom of the machine. It’s worth going there and seeing something. If yes, then what? In general, I don’t understand anything about these matters. Or is it easier to order and...
