Colleagues. The lock on the AEG is worn out. You need a dispenser cover 4006078028. The thing is not unique, it is also suitable for Electrolux, but you can’t afford to buy it for 2000 rubles. Maybe someone has it lying around? Peter
Hello. It leaks through the dispenser seal on the PMM KDI 45570 and I can’t figure out how to remove it. Could you explain to me how it is attached and how it is removed. Saipu dispenser number model sp-d02b.
Thank you.
bosch dishwasher The rinse aid dispenser is leaking. When I pour it, it immediately flows out, the dishwasher is 10 years old.
What should I do? Apparently the problem is in the seal (or I’m mistaken). Where to buy, how to change? If you call a repairman, how much does the repair cost in Moscow?
