Water leaks from valve SMV25AX00EBosch
Like Tishka
Post by Like Tishka »
Good day to all! I bought a dishwasher 9 months ago, just now they connected it. When I turn on the water for the dishwasher, water starts flowing from the valve at the bottom of the left wall (see photo) and water collects in the pan. Turning it on/off did not give any reaction. The car is new, it has never been used. Is it a defect or did I miss something in the instructions?
Water leaks from valve SMV25AX00E - IMG_7661.jpeg (16.12 KiB) Viewed 1211 times
Alexander SZAO
 Re: Water leaking from valve SMV25AX00E
Post by Alexander SZAO »
Good afternoon!
I encountered a similar problem: water flows out of this hole after the washing cycle is completed and the pan is filled about a centimeter above the filter mesh.
Tell me, did you manage to figure it out somehow? with this problem?
or is this normal and how it should be
  • Water leaks from the vent
    by Alex » » in Bosch
    Last post by Air Shower
  • Water is constantly flowing from the valve
    by Didis » » in Samsung
  • When connected to the network, the water inlet valve turns on and does not turn off.
    by DenisM » » in Electrolux
    Last post by Vlad766
  • candy trio 9501x water intake valve does not turn on
    by borodinaries » » in Candy
    Last post by borodinaries
