SMS50E02 error E04.Bosch
VAZ
My dishwasher: bosch SMS50E02RU
 SMS50E02 error E04.
Post by VAZ »
It all started with the fact that the water supply stopped, E15 and the red indicator against the mark with the tap came on. Instead of reading the forum and just rocking the car, I first dismantled the floor of the car and was about to change the aquastop valve. Then I figured out how to supply 220V to it, made sure it was working, put everything back together, shook the car, the valve started working, and water started flowing. But apparently I caught something there by accident during installation and dismantling. As a result, after assembly, at the end of any program except rinsing, error E04 comes on, but this would be half the trouble, but the water does not heat. Although the error codes about E04 say that this is an error in the water flow switch and it does not seem to have anything to do with the heating element.
VAZ
 Re: SMS50E02 error E04.
Post by VAZ »
Everything turned out to be banally simple. When I was disassembling and moving the car, I forgot to close the container with salt. A decent amount of salt poured into the box, got into the channels where the flow switching disk, the water dried up, the disk became coked with salt and apparently stopped moving. I took everything apart, washed it, it works, no problems.
If only I could post a photo it would be great
A bird
Post by A bird »
Photos please of how the car was dismantled. Same bullshit, but how can I take it apart? Or a link where you can watch it.
  • error E31
    by Anastasia » » in Bosch
    Last post by Cheer up
  • error E22
    by Evgenia » » in Bosch
  • Error A05
    by Langollier » » in Hotpoint-Ariston
    Last post by Aksenov
  • Error E 27
    by Vitaly » » in Siemens
  • Error e17
    by Victor » » in Bosch
    Last post by Victor
