Dishes in the upper basket are not washedBosch
Basil
My dishwasher: Bosch SMV63MOOEU
Post by Basil »
Hello!
Model SMV 63M00EU. The dishes in the upper basket are not washed. First of all, the inside of the cups remains covered in dried tea leaves and food debris. The car is 6 years old. The last six months have been getting worse and worse.
Thanks in advance for your answer.
Have you looked at the injectors in the upper rocker arm? Sometimes these small holes become clogged with fish bones and other food waste.
Basil
Post by Basil »
Thank you for your response. I forgot to write that I removed the upper impeller and examined it carefully. There are no blockages. Apparently, there is insufficient water pressure supplied to it. The lower one is normal, and the upper one is insufficient.
  • The dishes are not always clean, there is a white coating, the powder is not washed out and sometimes gets attached to the dishes.
    by MyDoHoles » » in AEG
    Last post by Arseny
  • Upper basket guide jammed
    by Lyudmila » » in Bosch
    Last post by Lyudmila
  • Dishes smell like dog after being washed
    by Tatiana » » in Bosch
    Last post by Guest12345
  • The salt is washed out in one cycle.
    by traumatologist » » in Midea
  • Can knives with wooden handles be washed in the dishwasher?
    by Sergey » » in General questions about dishwashers
