Dishes smell like dog after being washed ⇐ Bosch
Автор темыTatiana
- Интересующийся
- My dishwasher: BOSCH SPS 40 E 02
Please help, maybe someone has encountered such a problem! The dishes, after being washed in the dishwasher, stink of dog!! Disgusting smell, but the dishes are clean and shiny. I changed the tablets, rinse aid, salt is always available. I wash the inside of the dishwasher regularly, the filter, the walls. I tried running it with baking soda and vinegar. Nothing helps (((
Andrew
Re: Dishes smell like dog after being washed!!
And where do you live? If in a country house, then maybe there is a mouse stuck inside?
Автор темыTatiana
- Интересующийся
We live in an apartment. Mouse excluded (
Sent after 1 minute 15 seconds:
The smell is like a dog after rain ((
Sent after 28 seconds:
Arthur
The same problem with the smell of dishes after washing. Here I can say this: we have a second dishwasher in the family. Now it’s whirlpool, before that it was beko. A similar smell appears after 1.5 years of operation of any machine. New cars don’t smell, no matter what product you use. As soon as the smell appears, nothing helps, I tried everything. Now I’m already thinking that this is a malfunction of the machine itself, perhaps some gaskets or the pump is not working properly, I will contact service.
Arthur
... and yes, the dishes really smell like dog))) surprisingly, of course.
Eugene
Hello! Same problem. I’m already sick of it. Are there those who managed to defeat this foul smell? At least there would be no smell on the dishes. Otherwise, after each wash you have to rinse the dishes by hand.
I recommend that anyone who encounters this problem clean the drain hose and the place where it connects to the sink drain. In a dishwasher, the drain hose is usually connected to the right side; you need to remove the side panel. In some cases, it may be necessary to clean or replace the drain pump check valve. But to do this you will need to remove the tray or bottom cover (depending on the design). I had this problem after 6 years of use. After some time, the dishwasher stopped draining water altogether. During the cleaning process, half a kilogram of crap came out of the drain hose. The smell of the dishes compared to the smell of "this" seemed like a fragrance.
Автор темыTatiana
- Интересующийся
I see that many people have this problem! In my environment, among the owners of PMM, no one believes that dishes can smell like that. We checked the drain hose, everything seems to be normal. The water drains normally and does not stagnate. It’s not clear what it is. But the car is completely new and less than half a year has passed. And we eat everything that is not greasy, we remove the leftovers from the dishes, I wash them often. And by the way, there are times when the dishes don’t smell)))
Sent after 1 minute 11 seconds:
Please unsubscribe from those who have coped with the smell. We will be looking forward to your answers!!!
Maybe it depends on the water? In Murmansk we have never heard of such smells...
Good evening, I also have this problem.... I had no problems for 1.5 years... then the smell appeared and that’s it... I reduced the air conditioner - it helped for 3 months... then the smell appeared again - I increased the air conditioner... .. now - the smell appears every once in a while... in a new way - first I run the soaking program, and only then the main one.... I read all sorts of things here - I’ll try to clean the hose and valve... maybe it will help
Автор темыTatiana
- Интересующийся
Do you also smell like a wet dog?
Sent after 16 minutes 56 seconds:
Sent after 6 minutes 14 seconds:
Do you smell exactly like a wet dog? How to clean it, please let me know if it helped or not)
Well, yes, it’s a dog... but it’s strange - sometimes there’s a smell, sometimes there’s not.....
Автор темыTatiana
- Интересующийся
And what should I do? I’m thinking of contacting the service
Sent after 1 hour 46 minutes 44 seconds:
The dishwasher is under warranty, but the service center said that this is not a warranty case
and that you need to invite a technician and he must take it apart
The smell of a wet dog, the machine is half a year old. It doesn’t always stink, once a week it may not stink...
It’s the same.Tatyana: The water drains normally and does not stagnate. It’s not clear what it is. But the car is completely new and less than half a year has passed. And we eat everything that is not greasy, we remove the leftovers from the dishes, I wash them often. And by the way, there are times when the dishes don’t smell)))
I live in Monchegorsk, after a year of use, I also got the feeling that a wet dog was wiping my dishes every now and then
Автор темыTatiana
- Интересующийся
When will it finally change how to deal with it.! The service centers openly laugh at this and claim that no one has such a problem!! By the way, it has gotten colder and the smell has become much less frequent!
- Участник
Try washing the dishes without detergents, it might be the problem. Especially pay attention to the tablets. There may be a problem that the products are not completely washed off; alternatively, you can experiment with a rinse aid.
It is quite possible that the problem is in very hard water, if your water is really hard, you must definitely add salt and set its consumption to maximum. The fact that dishes sometimes don’t stink is in this case due to the fact that the hardness of the water changes.
Just in case, you still need to thoroughly clean the filters, there are two of them, one cylindrical, inside.
Автор темыTatiana
- Интересующийся
We experimented in different ways, with tablets and powder and without detergent, and still there was the smell of a wet dog, and the dishes were clean, but they stank terribly. I make sure to wash the filters, the dishwasher is always clean, I also clean it once every two weeks, I run it with a special cleaner. With the product or with vinegar and soda. Nothing helped!! The dishes stank disgustingly of dog. But what’s interesting is that it just got colder, and the dishes don’t stink!! mysticism!
In the warm season, the water in the reservoirs blooms. Maybe because of this?
Автор темыTatiana
- Интересующийся
- Участник
In summer the water blooms, and in cold weather the hardness drops; the problem can be solved by adding salt for PMM
summer is over and there is no stink at all... Everything is clear, in the heat, wash dishes by hand)))
Alexey
My wife and I also faced this problem. I surfed the Internet and found OdorGone Home. Quality product from America. We purchased it, processed it, and within a few hours there was no trace of the smell left. Checked it out from personal experience!
Автор темыTatiana
- Интересующийся
Did you smell like dog? On a regular basis or sometimes? We sometimes smell, and then only the dishes (
I wash the dishes with my hands and I also got this smell
I don’t know what to do now((((((
I think it’s a matter of input and how to deal with it concepts I do not have(((((
Antoha
Hi all. Someone wrote about Murmansk))) We have the same problem in the Murmansk region (Monchegorsk). It stinks of dog or rotten stuff
In general, I’ll tell you my observations.... the smell appeared after half a year of using the dishwasher, I tried buying products for the washing system and the dishwasher itself. It didn’t help, or at least for a while... In general, my girlfriend is VEGAN, and she doesn’t eat meat, very often there are times when we just don’t eat meat... and we don’t wash the dishes in which we ate meat and, strangely enough, the smell disappears FULLY! By the way, this also applies to EGGS!!! I noticed that if you buy cheap eggs there is a smell!!!! if there is no more expensive one... in short, this is from my observations
Nadin
Our dishes get this smell if the window in the room is open. It is impossible to drink or eat with the balcony open. The same dishes do not stink without air access. By the way, we have a second dishwasher and the problem remains. At first the smell was a little less. I’m thinking there might be a problem with the connection to the drain. We even conducted an experiment: we took the dishwasher itself into another room and the smell disappeared. And in Turkey, glasses stink just the same if you drink them on the street.
Автор темыTatiana
- Интересующийся
It’s probably a matter of water, or some components in detergents when they come in contact with water. I washed the mirrors and the floor (tiles) and after cleaning, I walked into the hallway and there was a strong smell of dog, the same as on the dishes after washing in the dishwasher, I sniffed the mirror and the floor and was shocked, it smelled disgustingly like dog. (((
Same problem. We bought a new dishwasher, nine times out of ten there is a dog smell. If you drink clean water from a washed mug, the aftertaste of dog remains. It sounds funny, but I want to cry... BOSH car, June-July, Chelyabinsk, we live in an apartment. WHAT IS THE REASON???
Автор темыTatiana
- Интересующийся
I don’t know what to do anymore, it’s disgusting to eat from smelly dishes. Yesterday I cleaned the apartment again, washed the floor and mirrors, and after cleaning the apartment it smelled terribly like dog, I sniffed the tiles and mirrors on the floor and realized that the floor and mirrors stank. She opened the tap and began to smell the water, but it did not stink. Now we can conclude that the problem is in the water, but why don’t the bathtub and sinks stink? Why do the dishes sometimes stink and sometimes, after washing, the floor and mirrors?!!!
And instead of rinse aid, I use vinegar essence, which is 70%. And the dishes after washing have a slight vinegar aroma. And it shines, too.
But I don’t know if this will help against the dog smell, I’ve never had that happen.
Автор темыTatiana
- Интересующийся
Al - Alexander
I have the same problem. That same dog smell. I thought it was just me, I’m honestly surprised that this problem is so common.
The dishwasher has nothing to do with it. I have not it. I don’t use any Fari.
I wash by hand with LAUNDRY SOAP. Ecology 100%. Sometimes I wash it with soda.
Then you smell the shiny dishes and that dog smell. But not always. Sometimes there is, sometimes not. I noticed that the smell appears when you rinse with cold water at the end.
In addition, the situation is similar with underwear. I washed it, hung it outside to dry, it was evening, there was no sun, it started to rain, I took off my underwear and smelled it - it had about the same smell as the dishes. At the same time, I forgot to hang one small rag from the wash on the rope and left it wet in the basin. Then I sniffed it specifically for comparison - the laundry from the street smells, but there is absolutely no smell from this rag.
In general, all this is completely incomprehensible. What is the reason? Maybe some kind of bacteria?
We need to continue researching.
Автор темыTatiana
- Интересующийся
Maybe it’s the water? What kind of water do you use? Although our water doesn’t stink when you smell it ((
Al - Alexander
The water should be good. A pumping station takes water from the horizon on the bank of a large river. There are no pollutants nearby, there is minimal industry, and there is some downstream about five kilometers, treatment plants are even further away.
However, the water, no matter how good it is, goes into the apartment through pipes and, according to Bernoulli’s law, can be sucked in at the joints of the pipes some kind of rubbish if it lies in the liquid, which is quite possible.
However, not only water plays a role here, but also something else.
I quote a previously written message in your topic:
"Our dishes acquire such a smell if the window in the room is open. It is impossible to drink or eat with the balcony open. The same dishes without access to air do not stink. By the way, we have a second dishwasher and the problem remains. At first the smell was a little less. I’m thinking maybe there’s a problem with the connection to the drain. We even conducted an experiment: we took the dishwasher itself into another room and the smell disappeared. And in Turkey, glasses stink just the same if you drink on the street."
It’s the same for me - the laundry on the street stank, but the rag that was left in the apartment did not. It was late in the evening, it started to rain and it was cool - 15-20 degrees. In general, we should try to study the issue from a scientific point of view. So far, everyone was just making observations, and no one seemed to be trying to experiment.
Автор темыTatiana
- Интересующийся
When, recently, I washed the floor and mirrors in the hallway, after a while a terrible smell of dog appeared there. But there are no windows in the hallway, at the same time I washed the floor in the room where the window was open, there was no dog smell in the room. But the hallway smelled terrible, and after a couple of hours the smell went away. In the hallway there are tiles on the floor and a large closet with a mirror along its entire width; there is laminate flooring in the room. In our kitchen we have a table with a glass surface, so when you wash it with a damp cloth, it often starts to smell like that same dog. And now I remember that it’s the shiny kitchen items, plates, cups, spoons that stink... For example, I didn’t notice that the frying pan or cast iron utensils stank. Although the boats stink, even though they are plastic...
Al - Alexander
I’m talking about the same thing. Metal pots or pans never smell. The smell comes from ceramics and glass.
Ie. some kind of reaction occurs. The reagent can be a substance found in water. For example iron. And glass or ceramics can act as a catalyst.
Or the smell may be caused by microbes multiplying on the surface. Although this is less likely.
The temperature of the water or dishes is also important. It seems to me that the process occurs at a fairly low temperature, below room temperature.
To check, try connecting the dishwasher to hot water, if you don’t have boiling water, of course. Or after washing, pour hot water over the dishes. Will the smell then disappear?
I will take water from the water pump at the dacha and wash it with this water, having first cooled it to the temperature of cold tap water.
Автор темыTatiana
- Интересующийся
I’ll be sure to post when I try it. Thanks for the advice!
The reason is too soft water!!! We poured salt into the bottom of the car, + salt tablets, + our water is medium hard. As a result, the water turns out to be so soft that it is not able to wash off all the components from the dishes, and after drying this smell and slight stickiness remain, although the dishes look clean.
Salt is poured into the bottom of the machine. If I use tablets, I set the hardness level to zero, i.e. for soft water. If I use powder, I set the water hardness to the first level, i.e. for medium water. There are four levels of hardness: 0,1,2,3. I use the rinse aid in both cases.
After these settings, the dog smell disappeared!!! and the dishes squeak in your hands after washing.
Please post if this helped you.
I am answering my own comment.Guest: ↑02 Jul 2017, 15:29 Same problem. We bought a new dishwasher, nine times out of ten there is a dog smell. If you drink clean water from a washed mug, the aftertaste of dog remains. It sounds funny, but I want to cry... BOSH car, June-July, Chelyabinsk, we live in an apartment. WHAT IS THE REASON???
...And one moment. If I accumulate dishes in the car during the day, then every time I turn on a 15-minute rinse: load a couple of plates and rinse. And so on until the machine boots completely. Then I wash it with detergent at full speed.
Автор темыTatiana
- Интересующийся
Sent after 10 minutes 21 seconds :
Do you only have dishes with this smell? When you wash the floor and mirrors/glasses, is there no dog smell in the room? Above we wrote some more tips and assumptions about what this smell is associated with. I wanted to use these tips, but there has been no smell for a week now. The weather changed - it got colder (maybe this can be considered as a reason), in winter, by the way, this smell was very rare!
Al - Alexander
Let’s assume that this is true. Soft water does not wash away all the components.
Then the question arises - from what component does the smell of dog appear, if the plates are after different foods, why this smell was not there before washing and why does different people living thousands of kilometers away smell like dog? from a friend.
Empirically, you found a solution, but the reason is unclear.
And where is the guarantee that the rinse aid itself does not remain on the plates?
Автор темыTatiana
- Интересующийся
I washed the mirrors not with water, but with mirror/glass cleaner and they stank just as much(
I think the smell is caused by all components, but primarily by fat in the process of decomposition from detergents, vegetable or animal. Water that is too soft cannot wash it off from the dishes.
You can speculate for as long as you like. I’m wondering if anyone has tried changing the water hardness settings and what the result was. Now I have no smell, I’ve already washed it 5-6 times.
Автор темыTatiana
- Интересующийся
When this smell appeared, I tried all types of harshness, the situation did not change. But when the smell appeared not only on the dishes, I realized that the problem was not in the dishwasher.
ALL POSSIBLE OPTIONS FOR SOLVING THE PROBLEM!
Experience in using dishwashers has shown that dishes that have a “ventilation” function stink less (the door opens after the end of the cycle and moisture is expelled from the compartment with an air flow).
Actually, the options are:
1) Clean/replace the drain hose
2) Rinse the car using a special dissolving bottle
3) Stop using rinse aid (rinse aid is a biodegradable soap, which creates a thin film on the dishes, which precisely prevents the formation of plaque, but with a possible unpleasant consequence - increased odor) By the way, almost complete absence of plaque can be achieved through the competent use of salt, which softens the water enough not to leave a residue.
4) Set to modes without drying (but also, therefore, open the lid immediately after the end of the cycle so that the moisture accumulated there does not become damp and settle on the dishes.)
If it is not possible to set modes without drying (by the way, the "30 minutes/express" mode never "dries" the dishes), then just at least open the door immediately after the cycle and take out the dishes so that they do not have time to "roll in the dog".
5) And do not forget about the main rules of the dishwasher - The dishwasher does not remove all the dirt, but only helps to get rid of it - Before using the dishwasher, soak the dishes well and wash off all pieces of food that could in one way or another interfere with the normal operation of the machine.
6) Be skeptical about tablets, because they are more expensive, and in fact, they won’t make you any better (you don’t need these "5 IN ONE!!!!", because you can wash dishes efficiently in the dishwasher when you know how to use it.)
Good luck to you!
Good luck to you!
Автор темыTatiana
- Интересующийся
I don’t add rinse aid, I clean the dishes of food before putting them in the washing machine, and I always clean them with a special cleaning agent. I use regular PMM powder. But now it’s clear to me that the problem is not in the dishwasher, because after wet cleaning the floor and mirrors stink. Here in Kyiv it’s cool now and there’s no dog smell. But when it’s warmer, it often makes itself felt. And it’s interesting that the jug (glass) was standing with water (bottled) and there was no smell, but then suddenly it started to smell like a dog. And just as quickly, by evening, it no longer stank. However, we did not wash it. Mystic...
I think it’s because of the fish. I noticed that if you put the dishes in after the fish, the fish oil from the hot water scatters all over the machine. And it is very difficult to get rid of it. And since we eat fish periodically, the smell does not translate.
Автор темыTatiana
- Интересующийся
Fish is rare here. In our case, definitely not a fish.
Sent after 3 minutes 53 seconds:
Here I’m writing off - I take the dishes out of the PMM, I hear the smell again, I rinsed it with hot water, and still the plates stank
Timur
I don’t know what exactly you call the smell of dog, but I encountered the smell of ozone (ions) on dishes, and on different machines and in completely different cities. This smell is similar to the smell in the forest after a thunderstorm. It is quite unpleasant and harsh.
The reason for this is the operating principle of a water softener - an ion exchanger. However, I don’t know what exactly is the cause: a malfunction of the ion exchanger, the water hardness settings, or a resin that has lost its qualities.
One of the reasons could definitely be too soft water. Try lowering the water hardness setting. However, what was written here earlier about changing the settings depending on the use of pills or powder is not true! Changing the settings will affect the water hardness only after 3-4 washes. With this parameter you just set how often water and salt will enter the ion exchanger and saturate the resin with ions. Those. if you set the maximum setting, washed the dishes once, reduced the setting to minimum, the resin will still be very active and the water very soft.
Now about the "3 in 1" tablets. They do not contain any salt! There are just phosphates, like in washing machine powder. Tablets do not replace salt. If you use tablets, you still need to add salt and switch the hardness setting to the minimum value (but not zero). The resin still needs to be maintained in working condition.
So my advice is how to get rid of the smell of ions (what you call "dog"):
1. Find out the water hardness in your city.
2. Using the PMM manufacturer’s table, select the water hardness setting.
3. Draw conclusions only after 3-4 cycles.
Excessive softness can also lead to clouding of the glass (corrosion).
Increased hardness can lead to calcium deposits on the dishes.
4. Be sure to use rinse aid. Without it, there is a chance that the product will not be completely washed off from the dishes, especially if the water is hard.
If you use "3 in 1" tablets, you still need to add salt, and set the water hardness setting to 1 In this case, rinse aid is not needed. And now the most important thing is to NOT break the tablets! By doing this, you disrupt the order in which the layers are revealed. Either you use them entirely, or you don’t use them at all. You can’t rush from powder to tablets either. Use just one thing.
Good luck everyone!
P.S. Once again educational program: There is no salt in the tablets! Salt from the ion exchanger is not involved in the washing process! Do not break the tablets!
Good luck everyone!
- 2 Replies
- 33330 Views
Last post by Basil
- 1097 Views
Last post by Vincentov
- 23479 Views
Last post by alexander.team
- 3 Replies
- 2973 Views
Last post by Olga.leonidova
