Error E24Bosch
World
 Error E24
Post by World »
Tell me what kind of error is shown on my Bosch dishwasher
The display says E24 in red letters. There is a lot of water inside that does not go away. :(
 Error E24
It’s impossible to drain the water! Blockage. I had this happen, I used a cable to clean the pipe into which the water from the dishwasher drains, and also cleaned the filter on the machine itself, which unscrews in the center. There were some stuck bones there. I don’t know what helped, but after that the error disappeared and everything became normal.
Michael
 Re: Error E24
Post by Michael »
Today I treated the E24 error in Siemens with the same method. I washed the filter and used a brake cable from the bicycle to clean the drainage device.
The error disappeared, the machine is working. Thanks to the superior comrade for the information :muza: :friends:
 Re: Error E24
Well, yes, Bosch and Siemens are twin brothers. :angel: :friends:
 Re: Error E24
Friends! I had this problem a couple of times. E 24, and a full puddle of water inside. The error indicates a drainage problem.
In the first case, I pumped out the water with a rag, removed the filter at the bottom of the machine inside the chamber, under it there is a plastic plug that is removed, and we get access to the pump. This is a plastic gear. A lemon seed got in there. After removal, everything worked.
The second time these manipulations did not help, the pump turned out to be free. It was useful to look for the junction of the drain hose of the car with the sewer. I took off the hose, and there was all sorts of stuff there. Cleaned it. A metal cable or any available means are well suited for these needs.
To check the functionality of the drain: Remove the drain hose from the sewer pipe and lower it into an empty bucket. We turn on the machine in any washing mode. In good condition, the puddle from the machine will flow through the hose into the bucket, and the problem will disappear. If it doesn’t leak, we’ll look further for the blockage.
Good luck and easy operation to everyone!
zorro6250@mail.ru
 Re: Error E24
Post by zorro6250@mail.ru »
After error e 24, I blew out the drain hose with a pump, the error disappeared.
Llanfir
 Re: Error E24
Post by Llanfir »
Good day to EVERYONE!
I encountered the same problem. First I decided to clean the system with pipe cleaner. Did not help. I blew out the drain hose (I used a Zelmer vacuum cleaner - THIS IS A SONG!!!). Did not help. It turned out, like the previous friend (post dated 11/16/15), a lemon PIT. I removed it - and EVERYTHING WORKS!!!
PATIENCE, SKILLFUL HANDS and GOOD MOOD!!!
 Re: Error E24
I apologize, but how did they even get into this pipe?? Do I need to take something apart?
 Re: Error E24
What is the error in the FO2 dishwasher?
 Re: Error E24
Guest: 23 Feb 2016, 00:51 I’m sorry, but how to get into this pipe did you climb at all?? Do you need to disassemble something?
If the dishwasher does not drain water well, you can try this repair method viewtopic.php?f=21&t=172
Anatoly
 Re: Error E24
Post by Anatoly »
I just cleaned the filter, drained the settled water and added new salt - and everything was flooded😂
 Re: Error E24
If cleaning the filters helped, then the problem seemed to be on the surface, but fatty deposits inside the dishwasher still remain not only on the filters, so it is recommended to periodically use high-temperature modes; sometimes the problem is due to scale (when the PMM has been working for quite a long time). I repeat that you can read more about how to thoroughly clean the PMM from contaminants here viewtopic.php?f=21&t=172
Yuri
Интересующийся
Интересующийся
 Re: Error E24
Post by Yuri »
The drain pump is blocked by a foreign object. (Maybe a lemon seed, but more often I take out glass from broken wine glasses). From FD9101 to FD9108;
For younger models, i.e. Since 2012, you need to look for the cause in a broken hose or clogged sewer, because... Since 2012, the error code for a blocked pump is E25.
Elena_K
 Re: Error E24
Post by Elena_K »
Guys, THANK YOU SOOO MUCH for sharing the solution to the problem! Yesterday, following your instructions, I saved 3,500 rubles. :read:
Antenna
 Re: Error E24
Post by Antenna »
THANK YOU EVERYONE!!!
Olga Vilenskaya
 Re: Error E24
Post by Olga Vilenskaya »
Thank you so much!!! At 2 o’clock in the morning the machine was subdued, you can go to bed with a feeling of pride :)
  • error E31
    by Anastasia » » in Bosch
    Last post by Cheer up
  • error E22
    by Evgenia » » in Bosch
  • Error A05
    by Langollier » » in Hotpoint-Ariston
    Last post by Aksenov
  • Error E 27
    by Vitaly » » in Siemens
  • Error e17
    by Victor » » in Bosch
    Last post by Victor
