Indesit Disp 5377 dishwasherIndesit
Alexei
Post by Alexei »
When the program starts, the machine drains the remaining water and fills with clean water. After 1.2 min. water intake, a short signal sounds, drain and error 5.
The whole joke is that if, when drawing water, you turn off the supply tap until the machine beeps, and open it again - no error occurs! It continues to work as expected, but until the next drain-fill cycle. During the next process of drawing water, manipulations with the tap must be repeated, otherwise 1.2 minutes. dialing... draining.. error 5.. *x)
Has anyone encountered similar bullying?...
alex
 Re: Indesit Disp 5377 dishwasher
Post by alex »
Today we encountered... I couldn’t find an answer on the internet, maybe you somehow managed to solve the problem?! Help
Maybe it will help someone. The situation was that the hose (drain) near the sewer pipe flew off the fasteners and fell to the floor. Thus, the location of the hose turned out to be lower than the dishwasher itself, and therefore the water itself drained from the dishwasher immediately after filling (although the dishwasher did not give such a command) and error 5 popped up. It was discovered by simply pouring water from the ladle into the dishwasher (in the off state) - the water itself was decreasing. After lifting the hose, the water stopped decreasing, turned on the dishwasher and the error no longer appeared.
  • The Indesit DISR 16B dishwasher does not turn on after a short circuit.
    by Evgeniy123456 » » in Indesit
    Last post by Evgeniy123456
  • Indesit DIF 14
    by Begil » » in Indesit
    Last post by Begil
  • Indesit DSG 0517 is leaking
    by Vadim » » in Indesit
  • indesit 0507 works but there is a hum
    by Sabina » » in Indesit
    Last post by Sabina
  • Indesit DSG2637 NTC sensor
    by Alexey22 » » in Indesit
    Last post by Alexey22
