The Indesit DISR 16B dishwasher does not turn on after a short circuit.Indesit
Evgeniy123456
Post by Evgeniy123456 »
Hello. The situation is as follows: the tray with detergent stopped opening during the washing process. They called a technician, and upon opening the front panel on which this tray is located, a wire from the terminal that connects to this tray was found to have fallen off. Well, naturally they returned it back and everything worked. The next day the same story - the tray does not open. So as not to wait for the technician, I decided to fix the problem myself, removed the front panel and saw the wire had fallen off, I tried to pull it out to sort out the connection, but I forgot to disconnect the dishwasher from the network and shorted this wire to the ground, knocking out the machine in the panel. Accordingly, after everything was assembled, nothing worked and the dishwasher stopped turning on altogether. I understand that I myself am a fool, well, anything can happen. Does this model have fuses or is it much more serious? I would be grateful for any help as informational, or maybe one of the masters will take on this problem. Thank you. My city is Tula.
  • Indesit DISR 16B flashing all indicator
    by hat » » in Indesit
    Last post by Anal cough
  • How to connect if the hoses are short?
    by अर्घः » » in General questions about dishwashers
    Last post by अर्घः
  • Indesit Disp 5377 dishwasher
    by Alexei » » in Indesit
  • The dishwasher won't turn off.
    by s.a.sha » » in Electrolux
    Last post by s.a.sha
  • I can't turn on the dishwasher
    by Ola from Nekrasovka » » in Dishwasher chemicals
    Last post by Ola from Nekrasovka
