The Indesit DISR 16B dishwasher does not start washing, after a while a beep sounds and ALL (six) indicators start flashing.
Tell me who knows
Indesit DISR 16B flashing all indicator ⇐ Indesit
Автор темыhat
- Новичок
Wear-resistant
Re: Indesit DISR 16B flashing all indicator
Thanks for the tip!!! I thought so, I just needed to make sure that I’m the only one who doesn’t know
the topic can be closed, I’ll delete the account today
But seriously, I’m waiting for a hint
I didn’t find any information on the Internet, there are no normal craftsmen in our village, our only hope is in a specialized forum. Help out.
Автор темыhat
- Новичок
Water supply valve?
I measured the resistance 3.8 Kohm, how much is normal?
Автор темыhat
- Новичок
checked the valve, under pressure, applied 220.... verdict - working
checked the leakage sensor working
in diagnostic mode it showed the following picture
the first 2 LEDs are on, the 3rd blinks like 9 times-
Автор темыhat
- Новичок
tray removed
Sent after 1 minute 23 seconds:
n uploaded a video, with blinking, you can watch it via the link on the Yandex disk
https://disk.yandex .ru/d/sBfeOf7h-wM1wA
as they say, it’s better to see it once
video duration 15 seconds. Everything is essentially.
Sent after 1 hour 32 minutes 40 seconds:
checked the pressure switch - working
Sent after 1 hour 18 minutes 8 seconds:
checked the turbine with reed switch - it works
Sent after 40 minutes 18 seconds:
Water does not fill if you leave the machine after a while the 2nd and 3rd diodes light up and light up
Автор темыhat
- Новичок
- 35748 Views
Last post by Evgeniy123456
- 33210 Views
Last post by ignat.barabano
- 10047 Views
