When installing the control board, I don’t know where to attach the sensor, which hangs on a wire soldered into the board. Stupid question, of course. Please tell me.
THE SALT SENSOR LIGHTS ON. I ADDED SALT UNTIL THE SENSOR WAS NOT GOING OUT. WHAT TO DO HOW THE SENSOR DETERMINES SALT PRINCIPLE OF THE DEVICE. WHO KNOWS, TELL ME. THANKS IN ADVANCE.
You need to mix with the handle of a spoon. (Deeper). The problem will disappear.
I can’t insert a link to the picture, the forum doesn’t allow it. the sensor is located on the side of the heating element, inside there is a “button” that the water should press on.
on the back side (not where the button is, but where the terminals are) there were strange orange smudges , the consistency is approximately like grease. What is this? Is there grease in these sensors and it has...
I measured the output signal of the sensor: Rectangular PWM with a frequency of 50-35 Hz depending on the water level. PMM self-diagnosis does not generate errors for an incorrect signal. Who’s in this thread? What should the signal from the sensor (presostat) be? Sensor code 30020274, PMM PNC 911656006/03.
