Can you tell me tableted salt for water softening? ⇐ Dishwasher chemicals
Автор темыIvan.semenov
The dishwasher in the cafe was damaged, as it turned out the problem was in the water. She’s too tough. You need special salt to soften the water. Which one do you use?
Defecation
Re: Can you tell me tablet salt for water softening?
We use special salt to soften the water in the dishwasher
Olga.leonidova
- Новичок
For each dishwasher, it is necessary to select the correct tablet salt. This will extend the service life of the equipment and increase its efficiency. A friend of mine has a restaurant, and sometimes they help me sort out the accounting documentation. And not so long ago I was just looking for a supplier in Moscow where I could order tableted salt for dishwashers and settled on this company http://dreammagic. ru/tabletirovannaya-sol/
Ksenia
Tablet salt for water softening for dishwashers that are used on an industrial scale must be present, it’s strange that you didn’t take care of this before
ivan. orlov
Tap water in pipes contains a large number of different impurities, which is why the water becomes more or less hard. You should do a water test first
- 6 Replies
- 39939 Views
- 3 Replies
- 8825 Views
Last post by Sibiryak22
- 5 Replies
- 38989 Views
- 4 Replies
- 40138 Views
