The gorenje gv66161 dishwasher squeezes out the rubber in the water supply pipe. ⇐ Burning
Автор темыenzof
- Новичок
- My dishwasher: Gorenje GV66161
Hi all. PMM 6 years. A couple of years ago, the water supply hose at the connection point began to leak. The problem was solved by replacing the factory wire clamp with a worm clamp. Now the rubber O-ring sealing the connection between the inlet fitting and the heat exchanger has squeezed out. There is an assumption that the flood of water has significant resistance in some place, but it is not clear where. The channels in the heat exchanger and ion exchanger do not seem to be clogged and are easily purged. What could be the reason?
- 21 Replies
- 66810 Views
Last post by enzof
- 2 Replies
- 43781 Views
Last post by Dmitry79
- 13014 Views
Last post by nickolai.cotov
