Problem with hansa zim654h - overflowsHansa
maxorlov
Post by maxorlov »
Good afternoon, there is a problem with the hansa zim654h dishwasher
It fills up water, thinks, fills in water again - like this 3-4 times
Water starts overflowing over the front edge
Then it gives the error "no water pressure"
At the same time, the pressure is normal, nothing interferes with the drain
Ie. Logically, some sensor does not detect the pressure
Tell me - what exactly should I look at/change first?
  • Overflows water. Leaking from water hardness regulator
    by Artem » » in Electrolux
  • Help identify the problem
    by Elena Alexandrovna » » in Hotpoint-Ariston
    Last post by Fastener
  • Interesting problem
    by Andrey1307 » » in Electrolux
    Last post by Video terminal
  • Help me figure out the problem.
    by Andsmol » » in Bosch
    Last post by Andsmol
  • Help me find the problem
    by www.diz_94 » » in Bosch
    Last post by Air Shower
