Interesting problemElectrolux
Andrey1307
My dishwasher: Zanussi de 6955
 Interesting problem
Post by Andrey1307 »
Hello! I encountered a problem with PMM Zanussi DE6955
When you turn on any program, the drain pump starts working for 5 minutes, after which error i20 lights up on the display.
If you pour water into the tank before starting the machine and after starting After a minute, fill it again, the machine starts working properly. The inlet valve opens, everything works great, but only until the first drain. After the first drain, no water is drawn and error i20 appears again. The pressure switches are working properly, I checked them with a multimeter. All water inlet and outlet connections are normal. Help me please (
Funtic
 Re: Interesting problem
Post by Funtic »
Perhaps your pressure sensor /pressostat/ is clogged with deposits from dirty dishes, remove the sensor and rinse
Andrey1307
I removed it, cleaned it, everything is fine
Video terminal
Post by Video terminal »
have you overcome the problem?
  • Freestanding dishwasher with an interesting design
  • Problem with fagor 1 vf
    by Sam » » in Fagor
    Last post by Sam
  • Help me find the problem
    by www.diz_94 » » in Bosch
    Last post by Air Shower
  • Problem with the dishwasher, where to dig?
    by saruar » » in Hotpoint-Ariston
    Last post by saruar
  • Help me figure out the problem.
    by Andsmol » » in Bosch
    Last post by Andsmol
