Help me find the problem ⇐ Bosch
www.diz_94
Bosch sd4p1b dishwasher, you turn on the program, the drain pump starts, then the circulation pump goes into different modes, then the water starts pouring, it pours for about 5 seconds and the draining immediately starts. The program stops and the faucet indicator flashes. I’ve probably already checked all the components, replaced the pump bushings, everything inside is clean, no scale, no traces of leaks, rust, etc. The tray is dry. Help me figure out what’s going on, where to dig??
Puppeteer
Re: Help me find the problem
Hello. You have solved this problem. I have the same thing, I can’t understand
Vyacheslav11
Air Shower
No, I haven’t found the reason, I’m sinning on the control unit, maybe something with the firmware
- 13227 Views
Last post by Romario 21
- 24944 Views
Last post by malamudra
- 10210 Views
Last post by vic2606
- 14926 Views
Last post by vital
