Help identify the problem ⇐ Hotpoint-Ariston
Elena Alexandrovna
The dishwasher does not complete the wash cycle. The power button begins to blink, the number 15 flashes on the display. The machine makes a sound as if it cannot drain the water. What could it be?
Ssg1234
Re: Help identify the problem
Help, otherwise this is some kind of devilry. PPM Gorenje. The mode selection button does not work, after which the machine automatically starts washing. Disassembled. I close the solder with a screwdriver - the modes switch. And the button too, everything works. But a few hours pass and it doesn’t work again. Using a screwdriver again, it works again. Replacing the button didn’t help. There is a diode and a resistor on the board with the button.
I don’t know what it is. Help? Otherwise, my wife will send for a new car)
IgnatyukAV
A similar problem, I sorted it out.... The heating element rings, there is no blockage. If you pour in boiling water, everything works. But if you don’t pour it, error 2 occurs and also tries to drain the water all the time.
Fastener
- 23014 Views
Last post by Mechanically
- 8 Replies
- 8491 Views
Last post by Andsmol
