Good day everyone!
Please give me some advice.
All of a sudden the machine started turning on/off spontaneously. The display lights up, but the program cannot be selected and started, after some time the machine turns off.
If you do not disconnect from the power, it will turn on and off. The nearest services are extremely far away.
Weissgauff bdw 6138 d turns on spontaneously ⇐ Other manufacturers
Автор темыbiomag
- My dishwasher: weissgauff bdw 6138 d
Dishwasher bot
- Новичок
Re: Weissgauff bdw 6138 d turns on spontaneously
1. Check the car battery. Make sure it is fully charged or try replacing the battery with a new one.
2. Check all wires and connections inside the machine to ensure there is no damage or short circuit. Also check connections to the display and other components.
3. If possible, try resetting the machine’s system. This can be done by unplugging the machine and leaving it without power for a few minutes and then plugging it back in.
4. If the problem persists, there may be a problem with the electrical system or machine control. In this case, it is better to contact specialists at the nearest service center or auto repair shop for diagnostics and repairs.
5. If the nearest services are too far away, it may be worth contacting relatives or friends who know about machines and electrical systems. They may be able to suggest some solutions or help you find a service center nearby.
I hope these tips help you solve your machine turning on/off problem.
In this situation, I would recommend the following steps:biomag: ↑Good day everyone!
adm2
- Администратор
Dishwasher bot, we are talking about a dishwasher. Think again.
Dishwasher bot
- Новичок
1. Dishwasher Bot with Utensil Placement Feature: This bot can help the user determine the best placement of dishes inside the dishwasher for maximum efficiency and space saving.
2. Dishwasher Bot: This bot can help users choose the most suitable dishwasher based on their needs, budget and other preferences.
3. Recipe Suggesting Dishwasher Bot: This bot can suggest recipes based on what’s currently in the dishwasher. For example, if you have leftover mashed potatoes, the bot can suggest recipes for using that mashed potato in a new dish.
4. Water and Energy Saving Bot: This bot can help users optimize their dishwasher to save water and energy. It can offer advice on how to optimally load the machine, use the right programs and additional features to reduce resource consumption.
5. Dishwasher Maintenance and Care Bot: This bot can offer tips on regular dishwasher maintenance, such as cleaning the filter daily or using detergents to descale your dishwasher. It may also offer instructions on how to fix minor breakdowns or problems.
Sorry for the misunderstanding. Below are some ideas for your "dishwasher bot":
adm2
- Администратор
Dishwasher bot, let’s do it again.
Out of nowhere, the DISHWASHER started turning on/off spontaneously. The display lights up, but the program cannot be selected and started, after some time the machine turns off.
Dishwasher bot
- Новичок
1. Check the power connection. Make sure that the power cord is carefully connected to the outlet and that there is no damage to the cord itself.
2. Check fuses. Make sure that the fuses in your house or apartment are intact and have not tripped.
3. Try rebooting the machine. Turn it off using the power switch or button, wait a few minutes, then turn it back on.
4. If the problem still persists, there may be a problem with the machine’s control system or electronics. In this case, it is recommended to contact a service center specialist. If service centers are located far away, you can try contacting the dishwasher manufacturer for further instructions or assistance.
But in addition to electrical problems, other factors such as software can cause this behavior of the dishwasher or system failures. Therefore, if you experience this problem, you should also consult your user manual or manufacturer’s website for more specific troubleshooting instructions.
The problem may be related to the electrical system of the dishwasher. In this case, it is recommended to perform the following steps:adm2: ↑Dishwasher bot, let’s do it again.
If you do not disconnect from the power, it will turn on and off. The nearest services are very far away.
Автор темыbiomag
- 1388 Views
Last post by Vsevolod Bogdanov
