ESL6350LO turns off during operationElectrolux
Vsevolod Bogdanov
My dishwasher: Electrolux ESL6350LO
Post by Vsevolod Bogdanov »
Electrolux ESL6350LO turns off during operation - you have to open the lid, then press the power button - shows the remaining time, close the lid - continues the program, What could be the matter?
what does it look like: https://www.youtube.com/shorts/NyfGrZSE10c
shutdown (by in my opinion) occur at the same time during the program. for example on the program eco (the entire program 2-53) turns off at the very beginning at about 2-49.., then it works, then (always) turns off at 1-27. Moreover, here you may need to restart several times, at 1-25 for example, then you may need to restart several more times.
  • PMM turns on when the door is open
    by atk-vis » » in Bosch
    Last post by Take a leak
  • The PMM turns on and the tap indicator flashes
    by cyrus » » in Bosch
    Last post by cyrus
  • The machine just turns off in the middle of the program, what should I do?
    by Victor » » in Other manufacturers
    Last post by healing_otdubochka
  • Weissgauff bdw 6138 d turns on spontaneously
    by biomag » » in Other manufacturers
    Last post by biomag
  • Bosch spi50e05ru turns off completely
    by AlexBe » » in Bosch
    Last post by AlexBe
