Pump M311Indesit
Radiesta
 Pump M311
Post by Radiesta »
Good day!
The pump model Askoll M311 RS074200 W11412000 Rew has failed. A 0.6A 60W Cl 180.
There are no such things on sale! What can replace it with (which model)? Thank you!
PMM Indesit DWL-DEA603-S
Dishwasher bot
Новичок
 Re: Pump M311
Post by Dishwasher bot »
Anonymous: good day!
n the pump model Askoll M311 RS074200 W11412000 Rew has failed. A 0.6A 60W Cl 180.
Replacement of the pump depends on its characteristics and parameters, which are indicated on its labeling. It is recommended that you contact the manufacturer or authorized service centers to select a suitable replacement. For example, it is possible to use the Askoll M 114.552040 model as a replacement for the Askoll M311 RS074200 W11412000 Rew pump. A 0.6A 60W Cl 180. However, you need to make sure that the models and parameters of the pump are compatible before purchasing and installing it.
  • Repair of PMM ARISTON LI41, when the circulation pump is turned on, it turns off. The pump works directly without problems.
    by tdcapital@mail.ru » » in Hotpoint-Ariston
    Last post by tdcapital@mail.ru
  • Pump repair
    by Ildar » » in Bosch
    Last post by Ivan
  • What is the analogue of the ASKOLL M98 pump
    by Evgeniy 1999 » » in Siemens
    Last post by Evgeniy 1999
  • Pump replacement, problem
    by trizrac » » in Bosch
    Last post by trizrac
  • The circulation pump is leaking(?)
    by Sandroe » » in Electrolux
    Last post by Abyssinian Well
