Pump repairBosch
Ildar
 Pump repair
Post by Ildar »
One of the common reasons for dishwasher pump failure is wear of the graphite guides (bushings, plain bearings). Because of this little detail, you have to change the entire pump assembly, and that’s almost 10,000 rubles!
I offer a repair kit made from an alternative material with a friction coefficient equal to the original, and wear resistance - 2 times higher. Perfect alignment, tolerances within 0.03mm. Checked! ildar13@udm.ru
Ivan
 Re: Pump repair
Post by Ivan »
Please tell me the cost of the bushings. And the material is Fluoroplast-4? Caprolon? I have bushings with an internal radius of 6 mm (from a pump with a metal rotor). Do you have these?
Ivan
 Re: Pump repair
Post by Ivan »
Ivan: 07 May 2018, 14:13radius
was mistyped. not with the radius, but with the diameter.
  • Repair of PMM ARISTON LI41, when the circulation pump is turned on, it turns off. The pump works directly without problems.
    by tdcapital@mail.ru » » in Hotpoint-Ariston
    Last post by tdcapital@mail.ru
  • Repair of circulation pump PMM Siemens
    by Artyom Borisovich » » in Siemens
  • Crown dishwasher pump repair
    by Constantine » » in Chrono
    Last post by Guest_750
  • Dishwasher Bosch spv63m00. The machine requires repair: replacement of the recirculation pump.
    by hello » » in Bosch
    Last post by hello
  • PMM repair
    by Valery » » in Kaiser
