Actuator O-ring 00644996(Bosch spv40x80ru)Bosch
VM88
Post by VM88 »
I suspect that there should be an O-ring in this hole for the gear, but I don’t understand which side and how high it should be. The problem is that water leaks through this hole and the gear.
Image Image
