Hello!
After replacing the circulation pump, the machine became very difficult to wash, even tablet does not always dissolve. I put the camera inside - the impellers do not rotate. The original faulty circulator is 9000.713.246. Replaced with Copreci 9001.375.885. I wanted to check actuator - there is no motor on it, just a plug that always directs the flow of water into 2 holes at once. Thinking...
I suspect that there should be an O-ring in this hole for the gear, but I don’t understand which side and how high it should be. The problem is that water leaks through this hole and the gear.
