Possibility of connecting to hot waterGeneral questions about dishwashers
Vitalik85
Post by Vitalik85 »
Hello.
The Bosch SPV 63M50 dishwasher has the ability to connect to hot water. If for some reason there is no hot water or it is not hot enough, will the machine itself heat it to the required temperature? Thank you.
It will heat up if needed. Look at the instructions, you may need to set "hot water connection" in the settings.
And ZZy
Новичок
My dishwasher: Ariston LS609 + Siemens SE66A590
 Re: Possibility of connecting to hot water
Post by And ZZy »
You can just connect. will not break if the water temperature is less than about 70 degrees
Disadvantage - it does not dry well inside the machine.
As already said, there may be an option in the settings "connect to hot water". read not only the instructions, but also the installation instructions.
If your machine has a heat exchanger (eco) installed, then the first fill it will still heat the water (mine seems to have it and it feels like that after the first fill, just open the door and feel the water - it’s cold? why? where did the hot water go....? and it’s there in the heat exchanger on the left wall) then it makes sense to drain it and add hot water, but the salt consumption will be increased in the load...
  • Connecting the dishwasher to hot water
    Last post by Sergey
  • Connecting the dispenser to Amika 80X
    by Alexei » » in Other manufacturers
    Last post by Alexei
  • Questions about connecting and operating the dishwasher
    Last post by Lydia
  • Connecting the circulation pump PMM Bosch SVM65M30RU
    by open » » in Bosch
    Last post by Air Shower
