Connecting the dishwasher to hot waterFlavia
Can a dishwasher be connected to hot water?
Many dishwashers are designed to connect only to cold water, since the dishwasher itself heats the water to the desired temperature, and different washing modes operate at different water temperatures.
In addition, hot water is of much worse quality than cold, which can lead to rapid wear of some dishwasher parts.
You should also take into account that hot water is usually harder than cold water.
Many detergents are designed to work in water, which heats up gradually, and not immediately hot, which can lead to poorer quality of washing.
The only advantage of connecting to hot water is that it will save a little electricity due to the fact that it needs to be heated. If for you this covers all the disadvantages of connecting to hot water, then here are a couple of models Flavia , which can be connected to hot water:
BI 60 PILAO
BI 60 NIAGARA
Novel
 Re: Connecting a dishwasher to hot water
Post by Novel »
What if I have a gas boiler with temperature control for heating and hot water?
Then, theoretically, any dishwasher can be powered from water heated to 40 degrees. S, right?
Theoretically, it is possible, you need to check with their manufacturers for specific models; in any case, it is better to connect to a cold one, but if you connect to a hot one, even 40*C, then perhaps some parts will fail faster. Although 40*C is not 60 or higher, any dishwasher can work more or less normally at this temperature.
  • Connecting the dishwasher to hot water
    Last post by Sergey
  • Possibility of connecting to hot water
    by Vitalik85 » » in General questions about dishwashers
    Last post by And ZZy
  • Questions about connecting and operating the dishwasher
    Last post by Lydia
  • Connecting the dispenser to Amika 80X
    by Alexei » » in Other manufacturers
    Last post by Alexei
  • Connecting the circulation pump PMM Bosch SVM65M30RU
    by open » » in Bosch
    Last post by Air Shower
