When the door of the PMM Beko 5930 is closed, there are clicks in the area of the control unit and the aquastop vibrates ⇐ Beko
+7 (919) 936-11-07
Guys, tell me if anyone has encountered this. I have PMM the following problem appeared. With the door closed PMM Beko 5930 clicks in the area of the control unit and the aquastop vibrates, while the button on the machine is not turned on, but the machine is plugged in. Now if you turn on the start button, it knocks out the RCD (automatic machine) in the apartment. Thank you in advance!
- 50957 Views
Last post by vincent007
