There is no power to the heating elementElectrolux
Ramsled
My dishwasher: Electrolux ESM94300LA
Post by Ramsled »
Hi all! The machine stopped heating (ESL94300LA) I thought the heating element was not ringing. I took it off and saw that one of the temperature sensors was not ringing and had burned out. I know the reason, they cleaned the car with the wrong product (there was a lot of foam), I soldered the temperature sensor directly to the Ten electrode, the circuit began to ring. I connected the heating element directly to 220 - it heats and does not penetrate the body. I assembled it, it doesn’t work, it was attached to a chip from the control unit, during the cycle the signal does not come to the heating element. I sent the unit for diagnostics - it’s fine. The temperature sensor, also known as the turbidity sensor, is clean, resistance 5 kOhm, decreases when heated, working. I exclude the pressure switch, because the machine runs the cycle flawlessly and does not give any errors. In service mode, error i60 - 6 flashes. The hoses for draining and collecting water are easily blown through and there is no dirt in them, the car is all clean without plaque or deposits. The tachometer is alive, I checked it by generating voltage while rotating the compass impeller. Please tell me, does anyone have any ideas on what else needs to be checked or corrected so that the signal to the Ten starts to arrive?)
Vlad
 Re: There is no power to the heating element
Post by Vlad »
Same story. Didn’t find a solution?
Ramsled
Post by Ramsled »
No(
Air Shower
Post by Air Shower »
The problem is with the pump, apparently it is not pumping up the required pressure. Today I installed another (used) one, everything worked, Ten started to heat up. 🤷‍♂️
Btnkh
Post by Btnkh »
I also have a problem with the heating element - sometimes it heats up on a short cycle, but not on others. What could be the problem? The thermal sensor is working, the heating element too, the module board is clean...
Air Shower
I have the same story, I call the chip on the heating element and it shows 035 v
Mountain Compass
Post by Mountain Compass »
Air Shower: 10 May 2023, 01:36 I have the same story, the chip on the heating element when I call shows 035 v
I have the same problem
  • No power to heating element
    by Rafis » » in General questions about dishwashers
    Last post by Rafis
  • How to find out which heating element is used in PMM?
    by Pigeon » » in Electrolux
    Last post by Pigeon
  • Checking the heating element. Help!
    by Inverter » » in Dishwasher chemicals
    Last post by Chirkash
  • The heating element Indesit DI 450 A does not heat
    by Dmitry.permyakov » » in Indesit
  • Voltage on heating element esl95210lo
    by SergeyS » » in Electrolux
    Last post by Concave Reflector System
