Voltage on heating element esl95210loElectrolux
SergeyS
Post by SergeyS »
Good afternoon
Please tell me. There is always 36 volts at the heating element connector. During the washing process it periodically rises to 220V, which, I understand, is the norm. But 36V always hangs at all, even if no program is turned on and PMM is not used.
Is this the norm? Where to look?
Yes, I came to take a look because the water stopped heating when washing.
I found that the heating element was broken, and I also discovered a strange voltage.
Thank you very much
Mihail138
 Re: Voltage on heating element esl95210lo
Post by Mihail138 »
Hello, the Electrolux dishwasher goes through the entire wash cycle, does not give any errors, and when you open the dishes at the end, they are cold, and the water does not heat up. Tell me what is the reason? And replaced the voltage with ten it showed 038
Concave Reflector System
Post by Concave Reflector System »
The machine will show errors only in service mode, and when you have the same error it will be easier to repair. Or dance with a tambourine, remove the wall, check the heating element, if the heating element is working properly, check the Megaohms for leakage to the body, if there is a leak, there will be no heating. But it’s better to start with the error that is in the dishwasher’s memory
  • How to find out which heating element is used in PMM?
    by Pigeon » » in Electrolux
    Last post by Pigeon
  • No power to heating element
    by Rafis » » in General questions about dishwashers
    Last post by Rafis
  • There is no power to the heating element
    by Ramsled » » in Electrolux
    Last post by Mountain Compass
  • Checking the heating element. Help!
    by Inverter » » in Dishwasher chemicals
    Last post by Chirkash
  • The heating element Indesit DI 450 A does not heat
    by Dmitry.permyakov » » in Indesit
