The heating element Indesit DI 450 A does not heatIndesit
Dmitry.permyakov
Post by Dmitry.permyakov »
Hi all. Help someone! The heating element is completely new, but any program is cold water. No matter what I did, I even acquired a brain, but it didn’t revive the heating element. Maybe there is a diagram? There, the zero immediately comes to the heating element through the temperature sensor, and the phase through the brain from the relay. I rang all the wiring (in case the lower harness breaks). Everything is whole. The machine is extremely simple, but it drank enough blood (. Who had a case from practice similar to mine? Thank you
 Re: Indesit DI 450 A heating element does not heat
Look in the settings, maybe you have the option to connect to hot water enabled.
Hello. There is no such thing. There is one incoming fitting (KEN).
There is no display, there are only 5 programs and that’s it.
  • Doesn't heat water. Heating element repair
    by mario » » in Bosch
    Last post by Ivan 1909
  • Beko DFN 6837 does not heat water, but the heating element works
    by seaman2 » » in Beko
    Last post by seaman2
  • How to find out which heating element is used in PMM?
    by Pigeon » » in Electrolux
    Last post by Pigeon
  • No power to heating element
    by Rafis » » in General questions about dishwashers
    Last post by Rafis
  • There is no power to the heating element
    by Ramsled » » in Electrolux
    Last post by Mountain Compass
