380V was connected to the electrolux esl94321la dishwasher.Electrolux
EvgeniyAndroid
Post by EvgeniyAndroid »
Hello everybody. This is my first time repairing dishwashers specifically. I will be glad to receive any help possible. A client brought a dishwasher, and according to him, 380 V went to the board. After that, the device does not turn on (it would have turned on after that). two 22 ohm resistors burned out. (R3160, R3002), varistors RV3002 and (RV3001) and also two fuses (F3001, F3000). What elements could still be broken through and in which direction should we look first? And is there a diagram for this model somewhere?
The name of the board is edw-pb150 01e.
vovans14
My dishwasher: FSR53617Z
 Re: 380V was connected to the electrolux esl94321la dishwasher.
Post by vovans14 »
the same board does not heat dishwasher. It doesn’t give an error, do you have any diagrams or ideas? I changed the relay, the heating element is good, I don’t know where to look!
Osmol
Post by Osmol »
EvgeniyAndroid, Good afternoon! This is exactly the same problem. Decided?
Goose
Post by Goose »
Is there a diagram?
Product
Post by Product »
the same board...
can anyone take a high-quality photo so that the components are visible?
otherwise the master put a signature on the board with a soldering iron..
380V was connected to the electrolux esl94321la dishwasher. - photo_5296479276754914425_y.jpg
Product
Post by Product »
If anyone needs, I can measure the components you are interested in
Abyssinian Well
Post by Abyssinian Well »
Good afternoon I’m interested in the resistance R3125, R3126 are on the board in parallel, burned out.
ig_night
Post by ig_night »
Please))
380V was connected to the electrolux esl94321la dishwasher. - IMG_20230728_083717.jpg
ig_night
Post by ig_night »
Abyssinian Well,
Is this photo enough?
Abyssinian Well
Thanks a lot
Ladle
Post by Ladle »
Abyssinian Well, my varistor RV3002 burned out, write the value. Thank you
Victor.Jesters
Post by Victor.Jesters »
EvgeniyAndroid, we made a dishwasher. Same problem.
Sergey
Post by Sergey »
Good afternoon!
Please tell me the nominal value of resistance R3140, after a short circuit on the drain pump, a triac with this resistance needs to be replaced...
Graphics
Post by Graphics »
Hello, please tell me who I can send a payment for repairs to. The cable between the control board and the main module was frayed, 220 was stitched onto the case. The cable was restored, now it gives the following iCO error (12 blinks) There is no connection between the board and the control panel.
Cargo
Post by Cargo »
ig_nat, Hello, can you send a photo of the R3005, which instead capacitor is soldered
AndreiDOm
Post by AndreiDOm »
Product, Good afternoon, tell me the values ​​of the resistor R3122 and the capacitor below C3075, it looks like
Sent after 1 minute 41 seconds:
ig_nat, Good afternoon, tell me the values ​​of the resistor R3122 and the capacitor below C3075, it seems
  • Overfill protection esl94321la
    by mamont_original » » in Electrolux
    Last post by nik
  • When connected to the network, the water inlet valve turns on and does not turn off.
    by DenisM » » in Electrolux
    Last post by Vlad766
  • Dishwasher Electrolux ESL46500R
    by Ivan Matskevich » » in Electrolux
    Last post by Ivan Matskevich
  • Dishwasher electrolux esl95321lo
    by Sergey 1975 » » in Electrolux
    Last post by Sergey 1975
  • Electrolux dishwasher door hinges
    by Alexander 34 » » in Electrolux
