Not warmElectrolux
Egos
 Not warm
Post by Egos »
Help. The problem is this. The heating does not turn on as expected. The whole pressure switch is new. The flow sensor is new. PMM works without problems but there is no heating. The heating turns on if, after 5 minutes of the cycle, you turn it off and turn it on with the button. During operation, the flow sensor does not rotate and does not change the flow between the blades. The second electronics have flashed the same firmware. It’s strange that the symptoms are still the same with 2 electronics. Only 60V ~ goes to the flow sensor
  • Doesn't wash well, but it's warm
    by radmir » » in Bosch
    Last post by radmir
