Overfill protection esl94321laElectrolux
mamont_original
Post by mamont_original »
Good afternoon.
Electrolux esl94321la, the overfill protection has triggered (triple beeping signal). From the outside there was a leak on the right, in the corner, from under the door.
I removed the side walls, saw water in the pan, accordingly, the float rose and hence the signal.
I drained the water, started the machine again - the pump took a suspiciously long time to pump water and the leak repeated. I open the door and there is quite a lot of water inside. It drains into the pan through two “saucers” and outlet hoses, left and right. I looked for information and came to the conclusion that, most likely, the water level sensor (pressure switch) is faulty, which is why the pump pumps water without stopping until it overflows.
And now the question is - where is the pressure switch located? for this model?
I couldn’t detect it visually, I don’t want to take everything apart. I couldn’t find any clear diagrams, illustrations or videos =(
Help, please.
p.s.
Nothing clogged, I didn’t find any blockages, I cleaned the filter, The water drains normally, the door seal is intact and clean.
Flash
My dishwasher: Electrolux
 Re: Protection from washable esl94321la
Post by Flash »
mamont_original, Good afternoon!
Did you finally solve the problem by replacing the pressure switch? I just have a leak from two hoses near the pan (the ends of which are simply fixed to the bottom) - I don’t understand where to dig
nik
Post by nik »
squeezed out the gasket of the receiving plastic bowl of the pallet, adjusted the gasket with a screwdriver (you can use tweezers, pushed it into the groove...) into place, - "normal flight" !!!!
  • 380V was connected to the electrolux esl94321la dishwasher.
    by EvgeniyAndroid » » in Electrolux
    Last post by AndreiDOm
